06-30-2024 18:48
06-30-2024 18:48
Hi there, My fitbit sense 2 screen randomly popped up yesterday evening unexpectedly and I'm not sure what happened. It was showing no signs of the seal being damaged and then it randomly popped up completely being only connected to the watch its self by the strip... the watch still works but yhe screen has completely popped up. I wanted to ask if there is any advice to fix this as I don't really want to buy a new watch. I've been using it for maybe 2 plus years and it has served me well even though the metal straps on the back have fallen off as well.
I have temporarily taped the screen back down with tape but any advice or support would be greatly appreciated. Thank you.
Best Answer06-30-2024 21:06 - edited 06-30-2024 21:08
Hi @Nani_nani - as the watch is still working it can be glued back on and a phone repair shop may be able to help with that delicate operation.
If it is still under warranty it can be replaced.
See also Metal trim on back of Sense 2 fell off
