Problem: When attempting to choose middle display stats for walk/run/etc. in exercise mode, app freezes, and needs to be restarted.
Steps to Replicate:
- Swipe on the watch face to "Exercise".
- Select an exercise. For example, "Walk".
- Scroll down, setting whatever options you like, until you get to stats.
- Click on "Middle"
- Check or uncheck desired stats
- Swipe from left side of the watch face to right to go up one level in the UI.
- Notice that touch interface no longer registers; you must press the side button to kill the app and start over.
Attempts to fix:
- Tried different combinations of stats
- Tried different exercises
- Factory reset the device and installed the latest version as of 29 APR 2026
Expected functionality: After selecting middle stats and swiping right, I should be able to scroll up to start the exercise with the new parameters.
Better solution: Put the configuration in the app on the phone and let it push down.
