12-06-2024
09:29
11:36
DavidFitbit
12-06-2024
09:29
11:36
DavidFitbit
After charging Sense 2 and pushing side to open Fitbit, logo pops up and then goes away. Can’t get code to set up.
12-06-2024 11:46
12-06-2024 11:46
Hi there @Ktirdil. It's good that the community is growing!
Let me help you with the setup of your Sense 2 smartwatch by following the instructions below:
- From the Today tab in the Fitbit app on your phone, tap the devices icon. (The one on the upper left that resembles a mobile next to a watch)
- Tap Add more devices.
- Choose your Sense 2 from the list and follow the on-screen instructions to continue.
During the instructions you'll be asked to enter a 4-digit code that should appear on your Sense 2 display.
If you don't arrive to see the code during the setup, attempt to restart your Sense 2 and try again. To restart your device, press and hold the button for 10 seconds until the Fitbit logo appears on the screen, and then release the button.
I hope this instructions will be helpful. Have a great day!
12:58
03:03
DavidFitbit
12-06-2024
12:58
03:03
DavidFitbit
The four digit code does not come up, The logo comes on screen and then a few seconds latere disappears.
Moderator edit: formatting
12-07-2024 04:46
12-07-2024 04:46
Hi @@Ktirdil,
I'm sorry to hear your Sense 2 doesn't work as expected. If the restart didn't resolve the issue, i suggest you contact technical support. They count with the tools needed to assist you further.
I hope you can find the support you need!
