05-07-2024
13:24
08:54
CrisVillaFitbit
05-07-2024
13:24
08:54
CrisVillaFitbit
Yes, I am very very disappointed with the sense 2 fitbit because of the draining battery and I don't have anything actually set up on it to drain the battery. As all of the other ones have noted it is a very bad design. I would gladly go back to my cheaper ones that lasted over a week but what I had problem with on those was not the fitbit but the terrible design on the band which kept breaking and so you couldn't wear the fitbit. I guess I'll have to go to apple.
Moderator edit: edited title to clarity.
Hello, @GrandmaBoBo and welcome to the Fitbit Community.
Thanks for informing me about this situation in regards to the battery of your Sense 2 and also, I appreciate the feedback about your experience with it.
I recommend you to check this article to help improve the situation with the battery.
Best AnswerI completely agree! And, if you go to that link from the moderator, it tells you to basically shut off everything that makes this a smartwatch! That's outrageous! Maybe they should have called this a tracker instead! I mean, one of the articles I read said to shut off heart rate monitoring! That's insane. My Fitbit Tracker, Inspire 2, constantly monitors heart rate, and it lasts a week workout a charge!
