01-03-2025
09:05
11:31
ManuFitbit
01-03-2025
09:05
11:31
ManuFitbit
My sense 2 will not stay on unless I have it connected to the charger. It will shut off as soon as it is removed and when it is reconnected to the charger it starts up. Every time it starts up on the charger it shows a different % of charge. Tried to reset when connected and that does not change anything.
Moderator edit: clarified subject.
Best AnswerHi @MJF33
Have you tried cleaning the charging pins on the charger and also the receiving pins on the back of the watch? Otherwise you could also try a different usb plug and if you have access to one, a different charging cable.
Welcome to the forums @MJF33.
Thank you for providing the details regarding this difficulty with your Sense 2.
In addition to the tips listed by @N8teGee, I'd suggest you take a look and following all the points listed in this help article:
Why isn't my Fitbit device's battery charging?
Thanks for your help @N8teGee
