11-01-2022
08:36
12:16
LizzyFitbit
11-01-2022
08:36
12:16
LizzyFitbit
I chose a few clock faces that have multiple color options available. However, there is no settings button available to change the colors.
Best Answer11-01-2022 09:55
11-01-2022 09:55
@rstoker apparently those two clock faces don't support changing settings on Sense 2.
Best Answer11-01-2022 08:52 - edited 11-01-2022 09:18
I think you would have better luck with a specific question such as "How do I change the color on XXX clock face?"
No guarantee it's the same for all clock faces.
11-01-2022 08:59 - edited 11-01-2022 12:43
If a clock face has options for colors or other changes, it is on the clock face screen in the phone app, if that clock face has a settings button under the picture of the clock face (after you have enabled it), you can change them there.
I haven't found where my 5 saved clock faces I have selected on the phone app show on my sense 2 watch screen. I upgraded from a versa 2, and I could scroll over to the 3rd party apps screens to tap clock faces on the watch screen and it would show me the 5 saved faces on my device and I could change my clock faces without having to open my phone. I haven't found a way to change my clock face without using my phone on my new sense 2 yet.
ETA - I have also noticed when I went to add a certain clock face I had in my versa 2 - it shows it as not optimized for sense 2. So it won't display right on the sense 2 screen so it's best to not use clocks that are not optimized for your Fitbit.
Best Answer11-01-2022 09:16 - edited 11-01-2022 09:17
I see the Settings button in the Android app for the Business clock face and colour selection. I believe it should be available for other configurable clock faces. Gallery->My Clocks->Select the clock->Scroll down and Settings is under the rating.
It isn't possible to change the clockface on the Sense 2, you need to use the phone app for that.
Best Answer11-01-2022 09:23 - edited 11-01-2022 09:24
I am using the app.
Gallery -> My clocks -> Select a Clock -> I see Rate Clockface, stars, and "see all details". There is no settings button. There are images above with several different style options for this an other clockfaces, but no settings available to change them.
Two of the clock faces I have tried:
Half & Half
Facet
11-01-2022 09:55
Best Answer04-07-2023 18:23
04-07-2023 18:23
Fitbit needs to bring back "Clocks" app so we can change clock faces directly on Sense 2 watch itself!
