07-21-2023 14:48
07-21-2023 14:48
Sense 2 will not turn on. I can only get the icon start up screen when it is plugged in but it will not go past that and does not appear to be taking a charge.
07-21-2023 18:09
07-21-2023 18:09
When you see the logo on the tracker, is Fitbit showing as connected on your smart phone? If yes, I would suggest holding the side button until you see the red X. Once it restarts, immediately do the same thing. Then again 1 more time (3rd time). Now hold the side button but let go once it reboots. You're only looking for a reboot, not a red X this time. Leave Fitbit app open and wait 20 minutes. Keep it charging. Eventually you should see a progression bar on the tracker. If you do, it's reinstalling all apps. Obviously your smart phone must have internet during this process and be showing as connected to the Sense 2 via Bluetooth in the Fitbit app. Goodluck!
Best Answer07-22-2023 07:40
07-22-2023 07:40
Thanks for advice. It appears that it will not connect with my phone. Does it matter that the only way I get the start up screen is if it is connected to the charger while trying to charge?
Best Answer07-22-2023 08:37
07-22-2023 08:37
I'm sorry to hear about the issue you're facing with your Fitbit Sense 2. If your device is stuck at the startup screen and won't turn on, here are a few troubleshooting steps you can try codes bellow codes: Press and hold the button on the side of your Fitbit Sense 2 for about seconds until it restarts. This can sometimes resolve minor software glitches
Best Answer07-23-2023 20:47
07-23-2023 20:47
The side button does not reset the device. Is there another way to reset the Sense 2? All I can get to happen is the blue diamond during start up but only when the devise is connected to the charger.
