11-13-2024
14:13
05:45
DavidFitbit
11-13-2024
14:13
05:45
DavidFitbit
What the title says. Even when I am lieing in bed, my watch often measures over 150 bpm which leavds me confused. It definitely should not be that high just before going to sleep.
Is this a malfunction or should I seek out my doctor? Because this is starting to worry me. 😅
Best Answer11-13-2024 15:11
11-13-2024 15:11
It should be easy to check yourself. Feel your pulse yourself at your wrist and count it to see if it is really 150+ or a more sensible number. If you can take your pulse manually just like the nurse does at the doctor's office, and it really is that high at rest, then you probably should see a doctor.
If your pulse beat seems normal when your take it manually, try switching to another clock face. It could be that one is just not updating heart rate correctly.
Best Answer11-14-2024 04:33
11-14-2024 04:33
Hi @JohnnyRow and Welcome @JuPe05 to the Fitbit Community! It's great to have you here. Allow me to help you with your concern about your heart rate reading with your Sense 2.
Excellent suggestion @JohnnyRow
If you believe your device is throwing some inaccurate data, you can always follow some tips to improve the accuracy of your Sense 2. In our help article How do I track heart rate with my Fitbit device? below the section "How do I improve the accuracy of a heart-rate reading?" you will find some tips to do so.
Note : Your Fitbit device is not intended for medical purposes. Consult your health care professional about any questions or health issues you may have.
I hope you will get the most out of your Sense 2 !
