04-20-2025 05:33
04-20-2025 05:33
Since a few days ago, I can no longer see daily/weekly/monthly/yearly data in the app.
Anyone else having this problem?
All I see is current day data. Is Google done with Fitbit?
04-22-2025 18:53
04-22-2025 18:53
04-22-2025 09:25
04-22-2025 09:25
I’m having the same problem since the last update.
Best Answer04-22-2025 17:49
04-22-2025 17:49
Following…having the same problem and its driving me nuts. I use that feature everyday
Best Answer04-22-2025 18:53
04-22-2025 18:53
04-24-2025 06:13
04-24-2025 06:13
You’re the MVP!!
Thanks! It worked for me too!
Shame that we even had to go through this and no assistance from Google/Fitbit.
04-24-2025 06:57
04-24-2025 06:57
Worked perfectly. Thanks!
And I’m disappointed that Fitbit didn’t either send a fix or at least a note on how to fix. I also note that other folks experienced other problems from the last update, too. Seems a bit sloppy at HQ.
Best Answer04-27-2025 14:45
04-27-2025 14:45
Did it delete your history?. I was going to do it, but it said if I remove the app, it will delete data
Best Answer04-27-2025 14:49
04-27-2025 14:49
It did not. That was my worry. But I was so frustrated that I went ahead and deleted the app and reloaded. All history was there.
Best Answer04-27-2025 20:46
04-27-2025 20:46
Best Answer04-27-2025 22:34
04-27-2025 22:34
For 3 days the app doesn’t let me do or save mindfulness time and results and now also the hourly activity not viewable on the app for +2 days . 2 things gone no way of correcting them . What next ?!
