Sense 2 not importing weekly/monthly/yearly data
ANSWERED
Since a few days ago, I can no longer see daily/weekly/monthly/yearly data in the app.
Anyone else having this problem?
All I see is current day data. Is Google done with Fitbit?
1 BEST ANSWER
Accepted Solutions
I deleted then reloaded the app. That fixed it for me.
9 REPLIES 9
I’m having the same problem since the last update.
Following…having the same problem and its driving me nuts. I use that feature everyday
You’re the MVP!!
Thanks! It worked for me too!
Shame that we even had to go through this and no assistance from Google/Fitbit.
Worked perfectly.  Thanks!
And I’m disappointed that Fitbit didn’t either send a fix or at least a note on how to fix.  I also note that other folks experienced other problems from the last update, too.  Seems a bit sloppy at HQ.
Did it delete your history?. I was going to do it, but it said if I remove the app, it will delete data
It did not. That was my worry. But I was so frustrated that I went ahead and deleted the app and reloaded. All history was there.
Thank you for your reply! I have six years of data. Don’t want to lose it.
For 3 days the app doesn’t let me do or save mindfulness  time and results and now also the hourly activity not viewable on the app for +2 days  . 2 things gone no way of correcting them . What next ?!
