I've been using my sense 2 for about 10 months now with no problems . I've had to completely un- sync then re- pair a couple of times but it's worked fine . Now it won't. My app is not finding my fitbit at all . I've done the usual complete shutdown, even deleted the fitbit from my account but I can't get it to pair up again . Any help would be welcome. Cheers .
Hi @Hillman123. Good to see you participating in the community.
Thank you for sharing the inquiry regarding the inconvenience with Sense 2.
I'd recommend you follow the steps listed below:
If you can't get started with your Sense 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
