03-15-2025
01:29
12:19
ManuFitbit
03-15-2025
01:29
12:19
ManuFitbit
New sense 2 this week. one of the Numbers in steps in this view is not showing. I have more than 617 steps. Correct in other views, but not in this one. Normal or an error?
Moderator edit: clarified subject.
Best Answer03-15-2025 01:30
03-15-2025 09:23
03-15-2025 09:23
Hi @Kbh50 - did you try restarting the watch, just in case.
The other option is to change to another clock face from Fitbit in case it has a problem but the one you are using may already be a Fitbit one.
If the problem persists for the clock face you have you could try contacting the developer, at the bottom of where you install the clock face.
To restart hold the watch button for 10 seconds till the display blanks or it vibrates and wait for it to restart.
03-15-2025 12:18 - edited 03-15-2025 12:18
Hi @Kbh50. A warm welcome to the forums.
Thank you for sharing the inquiry regarding your Sense 2 and for providing the pictures.
Please follow the suggestions provided by @Guy_.
I'd share the help article to change the clock face: How do I change the clock face on my Fitbit device?
Thanks for your help @Guy_.
03-19-2025 01:41
03-19-2025 01:41
Thanks. It turned out to be an error and delivered back to the store.
thanks anyway!
03-20-2025 13:57
