03-16-2025
16:18
11:54
LizzyFitbit
03-16-2025
16:18
11:54
LizzyFitbit
Welcome to the forums, @Valkaria123.
I'm glad you have a Sense 2 and I'd like to clarify that by default the Alexa app will come installed on your watch. If you'd like to set up this feature, I'd recommend the following steps:
For instructions on how to use the voice assistance on your watch, check this help article.
You may want to check your Location has Alexa support.
FYI.
You can change your location in the Fitbit app settings:
Hi there, @asiayeah.
Thanks for stopping by to help our friend. You're right about checking if they're located in a supported country. @Valkaria123 Please check both posts and follow the instructions provided as they will help you to get the Alexa app working on your Sense 2!
