11-12-2025
17:45
17:20
ManuFitbit
11-12-2025
17:45
17:20
ManuFitbit
Watch is fully charged and will randomly turn off. When I try to turn it back on, I get 3 logo flashes and a red X.
Only thing that works is putting it back on the charger.
yes I have already:
uninstalled / reinstalled the app, made sure my watch is fully charged, toggled WiFi switch on/off - toggle my Bluetooth on/off.
nothing works. This is a similar problem back in 2020 and the fix was a software update. That fix seems to be blocked by Google.
Moderator edit: clarified subject.
A warm welcome to the community forums @Anthonyj78.
Thank you for sharing with me the information about the difficulty that you are experiencing with your Sense 2 and for trying to fix it on your own.
Sorry to know that you previously experienced a similar situation.
As you indicate the device is turning on only if you put it back on the charger, I'd suggest you follow the steps listed here: Why isn't my Fitbit device's battery charging?
Once you managed to get the device charged, please give it a try the following:
Try to restart the device as indicated here: How do I restart my Fitbit device?
