That's so annoying, did you get any chance to do a reset or try anything else? You can do a reset by pressing the button for at least 10 seconds or do a factory reset using settings. Is it totally spontaneous or does it reboot after a notification or opening an app?
Best AnswerI've had at least two random reboots - one just happened. Also a few lockups where the hardware button had to be held down until it restarted. Honestly, random restarts seemed to be an 'undocumented feature' of Sense 1 as well as mine did it fairly often.
