04-24-2023
21:14
12:17
04-24-2023
21:14
12:17
Dotted frozen diamond display
No clock face
Won't sync ** even After it's been reset by side button ~
It's Only 5 Months Old!
Best Answer04-25-2023 03:12
04-25-2023 03:12
Welcome to the Fitbit community, @Coowoo!
Sad to hear that your Sense 2 isn't working as expected. Please try installing a different clock face to see if that will correct your issue. To do so, please follow the instructions provided here:
Sense 2 - Clock Faces, Tiles, and Apps
I'll keep my fingers crossed.
04-25-2023 03:12
04-25-2023 03:12
04-25-2023 03:41
04-25-2023 03:41
It worked!!!!! Now I want to go back to the original face. I liked it better. Does it have a name so I can find it?
04-25-2023 04:04
04-25-2023 04:04
Thanks for your feedback, @LindyLunea! So I guess you had the same issue as @Coowoo?
Charge 5's default clock face is called "Continuum".
04-25-2023 16:08
04-25-2023 16:08
Best Answer04-25-2023 16:18 - edited 04-25-2023 16:29
Maybe you have somehow a different problem. Mine was stuck on the weather app and changing the watch face in the cell phone app worked! I can now see the time! The second screen is just the Fitbit diamond symbol. I have to figure out how to select the other features like weather again, sleep, steps. - in other words back to all the original faces..
