09-30-2022
18:01
18:31
LizzyFitbit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
09-30-2022
18:01
18:31
LizzyFitbit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
just got the sense 2 3 days ago its dead i put it on the charger nothing this is my 3rd day wearing it I fully charged it last night this afternoon i tapped the screen to wake it up nothing click the button on the side nothing when I looked at the app its asking if I want to pair a device. get home put it on the charger nothing the dots in the back nothing. followed the steps to reset held the button for 10 seconds the fitbit logo appear screen goes blue the a BIG RED X what the H-LL
10-01-2022 01:57
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-01-2022 01:57
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi @Lheather, sorry to hear that.
Have you got a spare charging cable you could try (Sense 1 and Versa 3 use the same cable) to rule out an issue with your charging cable. If not I would recommend checking the pins on the end of the cable to make sure they are all able to spring freely and none are getting stuck down.
Other than that your next option would probably be to contact customer support (here).
10-03-2022
18:33
06:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-03-2022
18:33
06:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi there, @Lheather. @N8teGee Thanks for stopping by to help our member.
@Lheather Thanks for the details and the steps tried prior to posting. I'm sorry for the issues experienced with your Sense 2. I went ahead to check your details and it seems you already have a case created with our Support team. I'm sure they'll continue helping you, so please keep an open communication with them.
10-21-2022 20:50 - edited 10-21-2022 20:52
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Had this issue as well, sense 2 flashed bright pale green a few times then large red x. Also had an oddity with sense 2 not keeping good time, ended up returning. Did get sense 2 to charge eventually, would connect it, see the flashing and red x,,, then wait a few min, disconnect/reconnect magnetic cable again, usually be the third or fourth attempt at most it would then charge. Not an ideal solution obviously but something to try, also seemed less likey to red x if having a higher battery percentage when attaching. Did not have it long, probably less than 10 charge efforts before returning. Odd time issue, odd charge issue,,, that was enough messing around.
10-25-2022
18:41
06:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-25-2022
18:41
06:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi there, @SigitySym.
Thanks for your efforts, as well as sharing the steps that worked for you. I'm sorry you've had this experience with your Sense 2 and if by any chance this happens again, please let me know so I can continue helping you with this matter.
04-16-2023 10:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
04-16-2023 10:26
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I have a brand new sense 2 that won’t charge out of the box. I tried so many USB ports. But nothing works. These chargers seem to be faulty from the factory.
04-25-2023
15:29
06:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
04-25-2023
15:29
06:28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Welcome to the community forums, @sholsinger.
I'm sorry your Sense 2 isn't working and thanks for your efforts while working on this matter. I went ahead to check your details and it seems you already have a case created with our Support team. I'm glad they're helping you with this matter, and my best advice is to keep an open communication with them.
