there are a few posts on the forums that have the same issues mentioned. Perhaps it’s not your device but possibly a more general issue. Did it coincide to you installing the new App? Do you also have missing heart rate data during the same time period?
@EL1 After you follow those steps did it solve your issue? Or is it still an intermittent issue?
Best AnswerOn your App (not device) do you have gaps in the heart rate data displayed?
11-14-2023
09:19
13:21
ManuFitbit
11-14-2023
09:19
13:21
ManuFitbit
The heart monitor is working fine. Just the sleeping tracker stopped on the 22nd october.
Doesn't look there are any gaps.
Hi,
Still not working despite all the suggestions.
Actually it worked for 2 days but stopped again.
Just don't know what else to do
Best Answer@Dcaseieo If this helps; I found that turning Off Bluetooth on my phone overnight (disconnect the Fitbit Device from your phone) Then in the morning re establish the connection and sync the Fitbit App seems to work. I get full data then each day (so far) that I do that. Fingers crossed for you.
