02-27-2025
13:22
15:07
ManuFitbit
02-27-2025
13:22
15:07
ManuFitbit
Step count jumps then comes back down. Have no confidence in the actual step count . Is there a fix ?
Moderator edit: clarified subject.
Best Answer02-28-2025 13:49
02-28-2025 13:49
Mine has been doing that also for several days, don't trust my steps at all. Plus battery is getting low fast and sync doesn't always work. Totally frustrating.
Best Answer03-01-2025 03:16
03-01-2025 03:16
Hi @GLMTS - unfortunately there is no fix and it's obviously very frustrating - you can follow more here Unreliable step counting bug
It's related to processing on the Fitbit servers and syncing, the only workaround is to turn off Bluetooth and use the watch in standalone mode.
