12-25-2024
12:46
05:36
CrisVillaFitbit
12-25-2024
12:46
05:36
CrisVillaFitbit
I went through the Fitbit hosted page at strava.fitbit.com and connected it to my Fitbit account (now forcibly moved to Google) and it says my activities will start automatically showing up at Strava, but they don't. Any ideas?
Moderator edit: edited title to clarity.
Best Answer12-26-2024 05:41
12-26-2024 05:41
Hello, @mckennagene, and welcome back to the Fitbit Community.
Thanks for letting me know about this situation in regards to the Strava connectivity with your Fitbit app using your Sense 2.
I recommend you to try reconnecting your Fitbit and Strava accounts by going to the "Apps" section in your Fitbit settings, revoking access to Strava, and then reconnecting through the Strava website, you can use the same link you mentione, just make sure to enable the necessary data sharing permissions on both platforms. You can also sync your Sense 2 with your device.
