I have my Sense to set to track my walks with the GPS function. I like to map my walks. But what is frustrating is the watch will vibrate to alert me is is disconnected and reconnected. Where do I shut that notification off. Thanks.
Hi @bearpawqs - there may not be a setting for this as it is supposed to stay connected so is an error you should know about when there is an issue.
Best AnswerDoes Fitbit still moderate the forums? I’m experiencing this same issue since updating to 20001.194.61. There used to be a way to turn this feature on and off through the app, but I no longer see where to do that. The vibrating is driving me crazy when hiking in heavy brush. Sadly I might need to move away from Fitbit if I can’t get a fix for this issue.
