The vibration tone of Sense 2 has suddenly altered. Its very disturbing and I am changing to Light and Strong options on the clock face under settings, but still the same croaky noise. I restarted the device. I even looked for reverting any firmware update. Kindly help. Its just been an year and I think I am under warranty. But does this get changed? Does anyone experience the same here?
Best AnswerHi @ssnavs
What you are describing sounds like a hardware issue with the vibration motor. You mentioned that you have done a restart which hasn't solved the issue.
I would recommend speaking with customer support (here). Hopefully they will be able to check your warranty status and confirm which options are available to you.
It's unfortunate to report that the watch has completely ceased functioning. It's not syncing with my phone, and whenever I restart the device, it falls 10 minutes behind the actual time.
I intend to visit the store to have it checked as it's still under warranty. However, I'm uncertain whether I'll receive adequate compensation for the money I've invested.
