11-18-2022 15:00
11-18-2022 15:00
Will it be possible to change vibration for notifications as it's on sense 1 just 1 tap of vibration, 2 tap is little bit annoying
Best Answer11-27-2022 05:11
11-27-2022 05:11
Hi @Dav. - unfortunately the Sense 2 works differently and the display of notifications is not that user friendly. The vibration is often weak so if you are getting 2 it means you are less likely to miss a notification.
However some issues have been raised and there may be updates over time which correct the behaviour.
