12-08-2023 21:46
12-08-2023 21:46
I setup a recently received and successfully set up a fitbit Sense 2. One the first day of wearing it, I noticed that it would turn off after5-15 minutes, needing the button to be pressed to turn it back on. I restarted the watch, unpaired, repaired, force stopped the app, uninstalled and reinstalled the app, and the issue persisted. Then I factory reset the Sense 2. Now when I try to set it up again, I get a warning, "Trying to connect....Make sure your phone is near your fitbit" warning when in the updating portion of the set up. This update worked the first time. I tried the methods above several times and then applied the following method
Best Answer12-09-2023 12:10
12-09-2023 12:10
HI @Rednero - the fault in the new V4 Fitbit App doesn't seem to allow setting up the same watch again, it could be done in the v3 version.
In the above steps try to remove any occurrence of the watch so that the App sees it as a brand new watch rather than a reinstallation
12-09-2023 15:44
12-09-2023 15:44
@Guy_, thank you for the recommended procedure. Unfortunately, the issue persists.
12-09-2023 16:06
12-11-2023 14:12
12-11-2023 14:12
@Guy_ - Thank you again! I will contact customer support; a step I should have taken first 😉!
