Was a Sense 1 user for a while and got the Sense 2 and also an iPhone 14 Pro. I prefer Fitbit devices than Apple Watch because of long battery life and other stuff. Anyway, when it works it’s great but since I’ve had it it will randomly just stop doing things.
Like without any change on my side notifications will stop coming through to the Sense. I’ve found toggling the Bluetooth on iPhone usually fixes this for some random time.
When I wake up in the morning it will sync but the Sense apps like weather, today etc won’t show any data until I again toggle Bluetooth on and off.
Clearly it’s some sort of issue that needs fixing. Just curious if other people with same setup are having similar issues or not. I’m wondering if there’s something specific to me that’s causing this.
Best AnswerI just got an iPhone 14 Pro Max and I'm experiencing similar issues. Syncing is a little weird. It doesn't seem like the iPhone has a way to integrate the Fitbit to the iPhone. Also, the Sense weather app suddenly switched to Celsius and I can't get it to switch back to Fahrenheit. I can't get the Sense controls to connect so none of the phone notifications are coming through to the Sense. I've tried to do a factory reset a couple of times but it gets stuck on the "Sense found" screen on the app and says "connecting" at the bottom for an abnormal amount of time and I can't go further with it. Toggling the Bluetooth doesn't really do much for me.
It seems like there is a bug somewhere but I don't know if it's with the Fitbit or the iPhone.
Best AnswerI too just got an iPhone 14 max pro and am having issues with my Sense 2 syncing with the app. Frustrating. I had a Sense 1 and an iPhone 11 and never had any problems. If someone has an idea of how to fix this, it would be appreciated. Thx
