11-21-2022
09:59
14:42
LizzyFitbit
11-21-2022
09:59
14:42
LizzyFitbit
Hello
My fitbit sense 2 wont stop vibrating while being charged. It vibrates every 5 seconds or so. Can this be turned of?
I used a different charging block and it worked.
Welcome to the Community, @EveDW.
Thanks for bringing this to our attention. While this is odd, have you made sure there is a proper connection between your Sense 2 and the charging cable? If you haven't done so, let me recommend cleaning the contacts on your charging cable and watch with the steps described here. Once that is done, try restarting your watch to refresh its performance and monitor its behavior.
I have the same issue too, and when i detach and attach back the charging device, the battery percentage indicates atleast 5 to 10% more, the battery readings seems going crazy.
12-05-2022
12:46
06:13
DavideFitbit
12-05-2022
12:46
06:13
DavideFitbit
Is there a fix. Got mine today and its vibrating
Not working. My sense 2 is vibrating when charging. Its brand new today out of the box
12-05-2022
15:24
12:52
12-05-2022
15:24
12:52
@Joanna07 and @Sunnyf50 Welcome to the Community. @FloppyDrive Thanks for sharing your insights.
@Joanna07 Thanks for letting me know about your Sense 2. I went ahead to check your details and it seems you already have a case created with our Support team. Please keep an open communication with them, I'm sure they'll continue helping you with this matter.
@Sunnyf50 I'm sorry this is happening to your new watch. Because your posts didn't mention, may I know if you made sure there is a proper connection when plugging your watch to the charging cable? If that's correct but the issue persists, please give a try to the rest of the steps described in this help article and monitor its behavior in the next few days.
Best AnswerI'm having the same problem with my sense 2, brand new. Is there any way to fix it?
12-13-2022
18:12
03:20
12-13-2022
18:12
03:20
Hi there, @Sunnyf50 and @EveDW. @Martina.Carlsso Welcome on board.
@Sunnyf50 Thanks for trying the suggestions shared in my post. I see your point of view and I'm sorry you've had this experience with your Sense 2. Your feedback is appreciated and we'll keep working to improve our device, as well as the experience with it. You're always welcome back to the Fitbit family if you change of mind.
@Martina.Carlsso Thanks for joining this thread. I understand you have a brand new watch, but could you check if there is a proper connection with the charging cable? If you haven't done so, try the other steps described here and let me know how it goes afterward.
@EveDW Thanks for your efforts, I'm sure your post will help other members visiting the forums.
Best AnswerUsed a different charging block and it worked. Wierd since the first one i used works just fine when i charge my phone etc
Could it be that many Sense 2 came with faulty charging cables? I got my Sense 2 yesterday. I tried charging it for the first time today, it didn't work. It flashed fitbit logo several times and showed a big red x in the end. When I plugged the charger that came with my Sense 1 the watch showed it was charging. But when plugged with the charger that came with the brand new Sense 2 it wouldn't charge. I wonder if the bad charger ended up jinxing the watch itself.
Best AnswerThat just fixed mine thanks it was killing me.
Best AnswerMy sense 2 vibrates every 5 seconds while put on charging..i am unable to fix. It's a new device out of the box..any suggestion.
Best AnswerMine too, only had it a few weeks
05-16-2023
20:49
17:01
05-16-2023
20:49
17:01
Hi, there are several reasons for the vibrations, maybe it is experiencing slow or poor charging and changing power source can help, or simply go into watch Settings, scroll to the bottom and shutdown, this should stop the vibrations, allowing upto 90 minutes to charge should be sufficient.
A poorly cleaned watch or faulty charge cable can also cause problems.
Receiving notifications will also cause vibrations while on.charge and a pull down on the watch face to get to Quick Settings and turn on do not disturb will stop them while charging, but remember to turn it off after.
Hi everyone, and welcome to our new members. @Guy_ Thanks for always sharing your help!
Thanks for joining this thread and letting me know about your Sense 2. Let me clarify the steps shared in this thread were suggested to make sure the possible troubleshooting was exhausted. I'm sorry for any inconvenience this caused and I appreciate your feedback as it'll help us to continue improving.
@Prasen_m, @thed4rkestrose and @Malmaa Because your post didn't mention, may I know if your watch displays an error message when vibrating? Do you see any damage on your charging cable or the gold contacts?
Additionally and just if you haven't done so, restart your watch, make sure the contacts of your watch are aligned to the charging cable, and try charging it one more time to see how it responds.
Best AnswerI think we all instantly tried restarting our watches and checking the contacts with the wire, I did that without even googling. No error comes up, just the now charging screen. My watch was new this month nothing is broken, though the only way I've found to stop it is use an apple plug, where as before I was using a Samsung plug
