11-14-2022 12:25
11-14-2022 12:25
My Sense 2 won't wake the display when I twist my wrist like I'm looking at a watch (it was doing this when I first got it).
I've found the setting Screen Wake under Display, which says it's locked for sleep mode and that I need to turn off sleep mode.
I've found the setting Sleep Mode under Quiet Modes, which is turned off and disabled (i.e., it's not on, and I can't turn it on to then turn it off). The only Quiet Mode which is enabled is Focus Mode, which I can turn on and off.
How do I get the screen to wake on a wrist movement?
Thanks.
11-14-2022 16:37
11-14-2022 16:37
It's either Screen Wake or Sleep Mode. Easier to get to them both in Quick Settings by swiping down from clock face.
11-14-2022 16:37
11-14-2022 16:37
01-06-2023 13:08
01-06-2023 13:08
I do not understand what to do. Can you give me a step by step? Thank you.
01-06-2023 19:23
01-06-2023 19:23
Hi @pisces0304 - as @JohnnyRow says, if you pull down the watch face to get to Quick Settings, there you can disable Sleep mode and set wrist wake, as the former stops the latter.
