Sense2 GPS lost Vibration
Hello community,
Does someone know how to deactivate the annoying vibration from the GPS? When I'm jogging and entering the wood, the watch is all the time vibrating, which is very stressful. I've deactivated all kind of vibrations, but this one is not going away. I've found out that it has something to do with the GPS, as when I deaktivate in a Workout the GPS funtionality, the watch is calmly quiete 🙂
1 REPLY 1
Hi @SchmidiA.   Your Sense 2 is losing, then reacquiring the GPS signal.  The Sense 2 only had built-in GPS when it was released, but got dynamic GPS in a firmware update.  It is supposed to use your phone's GPS if your phone is nearby when you start.  I wear my phone is the same place when I'm outside.  I have good days and bad days when I use GPS.
You can see this for yourself.  The GPS icon on the watch switches from a solid icon to an icon outline when this happens.
Laurie | Maryland
