I connect my phone to bluetooth in the car and to my Jabra headphones. But just like my Car and Jabra automatically connect to the iPhone, my fitbit simply disconnects. And since it is extremely beneficial to have notifications on the watch, i spend hours together to fix it. But i am kind of getting a little frustrated since that reconnection is not always very straight forward and easy.
Any one facing a similar situation? Is Sense have some connection issues with Jabra so when Jabra is connected, Sense completely stops talking to that device (my iphone in this case)
Hi @SwapnaChat - the versions of the V4 Fitbit App can also lose connections independently of what other Bluetooth devices are used but it may also have a bearing on the matter.
If it is systematic you have your answer.
But see Why won't my Fitbit device sync?
Unfortunately there is no status indicator on the se6nse 2 to know if it's not connected.
