06-09-2023
08:16
11:54
AndreaFitbit
06-09-2023
08:16
11:54
AndreaFitbit
The sensor button on my sense 2 not working even after a factory reset. Can you help.
06-12-2023 09:40
06-12-2023 09:40
Thanks for getting back to us @Karatekata.
Please clean the button and let me know how it goes.
You can check: Wear & Care.
Best Answer06-09-2023 20:11
06-09-2023 20:11
Hi @Karatekata - did you do the factory reset from the menu? Is the button not responding to any press, such as holding for 10 full seconds?
If it is not working at all replace the watch where you bought it under warranty.
You can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support for more specific help.
Best Answer06-10-2023 11:53
06-10-2023 11:53
Welcome to the Fitbit Community, @Karatekata. I'm sorry to hear that your Sense 2 sensor button is not working even after a factory reset.
Have you tried cleaning around the button with a little alcohol?
Thank you for your advise @Guy_.
Best Answer06-11-2023 08:48
06-11-2023 08:48
Many thanks for your reply. I will try cleaning the sensor. The watch was activated on Christmas day 2021
Best Answer06-12-2023 09:40
06-12-2023 09:40
