02-18-2025 10:05
02-18-2025 10:05
Recently did the required firmware update and my Sense 2 went from 7 days between charging to less than two. Tried restarting but no change. What the heck.
02-19-2025 10:09
02-19-2025 10:09
Exactly the same for me!
02-19-2025 11:12
02-19-2025 11:12
Hi there! @Peakay606, @Gee45 A warm welcome to the Fitbit Community!
Thank you so much for reporting this situation and for all your efforts.
Do you have the Always on Display activated?
I suggest you follow the tips from this article: Can I extend my Fitbit device's battery life?
Please check if you have a Fitbit Sense instead of a Sense 2 and read this article too: Sense and Versa 3 Battery Performance Program
02-21-2025 00:06
02-21-2025 00:06
Hi,
My sense 2 is the same after that "battery overheating" update.
I´m pretty sure this was just a "planned obsolescence" update and they want us to buy a new watch.
The clues were that when fixing the thermal issue we would see shorter battery life, when in reality thermal issues with batteries are usually caused by too much battery consumption, so any fix should increase battery life. But as they warned, like they knew, the battery life would diminish.
Like some of you I came into the eco system through the Pebble watch, which I loved, the ideology, the online IDE and all the great stuff that Fitbit (and now google) has decided to sunset.
My next watch will most likely be something else, my wife has had Garmins for many years, I suspect I will go there, unless anyone here can recommend a watch that is more in the line of the original Pebble.
02-21-2025 08:33 - edited 02-21-2025 08:33
Hi there @jonhallur!
Thank you so much for reporting this situation. I'm sorry to hear that after the firmware update your Sense 2 is not working correctly.
I suggest you submit a request to find out if your device is impacted here and to follow the tips from this article: Can I extend my Fitbit device's battery life?
02-24-2025 11:20
02-24-2025 11:20
I’m having exactly the same issue as well! Fully charged up yesterday but has completely died by 6pm today.
Noticed that since the firmware update I’ve had to charge more frequently, but today the drop off seemed extra quick.
02-27-2025 14:45
02-27-2025 14:45
Mine has been doing the same here lately and seemingly getting worse. Charged it up yesterday and today it's already dead. I noticed yesterday when I pulled it off charge after a few minutes it jumped to 80%. Followed all the troubleshooting steps to no avail. Sometimes it lasts a full day other times it lasts half a day
03-02-2025
19:14
07:44
MarioSFitbit
03-02-2025
19:14
07:44
MarioSFitbit
My Fitbit sense 2 is doing the same thing after reading all these replies I think I’m going to a different name brand. I’m gonna try a Garmin next. I’ve had a Fitbit for many years now, this makes me ill with the company to hear their new update shortened my battery life to unusable by design!!
I had the same problem and for two days I couldn’t get my watch to even start, I was getting ready to throw it in the trashcan, and I kept trying to do the reset and I finally did a hard-core factory reset and it’s working again better than it did before
It wouldn’t surprise me to find out Fitbit did this on purpose. I struggled with my watch for three weeks and the last two days I couldn’t even get my watch to start it crashed. After charging it for two days straight I finally after trying 15 times I finally did what I think is called a hard factory reset and I got it working again. It’s working better than it did before
Do a hardcore factory reset it will work better than ever. Everything that’s in your Fitbit app on your phone will remain the same, anything that’s on your watch with the factory reset will be wiped out and you will be starting over
Moderator edit - Merged messages
Best Answer03-05-2025 15:48
03-05-2025 15:48
I don't want to disable functions I always used. If it lasted 6 days using all those functions, why is it only lasting 1 day with the same functions!!!! Not great. I want old firmware back
03-08-2025 12:29
03-08-2025 12:29
I'm having this exact issue too. Mine will hold a charge all weekend when I'm with my phone, but when I'm at work where I can't legally take my phone it dies within minutes. Apparently there's nothing they can can do but offer me 35% off their own store?
