08-26-2023 10:06
08-26-2023 10:06
Hi, when I tap my screen on Sense 2, the screen will not turn on,
I have to push the side button to switch on the screen,
I have turned it off and on,
any other help to get the screen to respond to touch would be helpful, thanks
Best Answer08-26-2023 13:57
08-26-2023 13:57
It's good to see you participating in the community @Amyom2023.
Thanks for the details regarding your Sense 2.
Have you tried to restart your device? In addition, I'd suggest changing the clock face.
08-26-2023 13:57
08-26-2023 13:57
08-26-2023 18:58
08-26-2023 18:58
I didn’t know this was supposed to happen. I only have the button or button/motion options to wake the device. Tapping the screen has never awakened the device. Is there a setting for this?
Best Answer08-26-2023 19:18
08-26-2023 19:18
@Amyom2023 @Pjsbend - double tapping the screen should wake it as well as button press.
If you pull down on the watch face and turn off all the icons it will wake the display when you raise your wrist to look at it.
Don't forget to visit watch Settings, Quiet modes to schedule a watch sleep time so that it doesn't automatically wake in the night, either from movement or notifications, this also dims the display, should you wake it manually in the night.
Best Answer08-26-2023 19:26
08-26-2023 19:26
Best Answer08-26-2023 19:29
08-26-2023 20:45
08-26-2023 20:45
Best Answer08-27-2023 00:11
08-27-2023 00:11
I have done that, still not responding
