07-29-2024 01:01
07-29-2024 01:01
I have a 3 and a half hour behind time
also how do I go back to Fitbit site from google pls
 Best Answer07-29-2024 04:24
                              07-29-2024 04:24
Hi, @Daisy1961! Your time should be set when you sync your watch. If you're still getting the wrong time, go into settings (gear icon in top right), date time and units, click time zone, and try setting it manually.
Unfortunately, once you migrate over to Google, there's no reverting the system.
MakMak | Community Council
07-29-2024 04:24
                              07-29-2024 04:24
08-15-2024 13:41
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              08-15-2024 13:41
@Daisy1961 Thanks a lot for sharing your experiences with us.
@MakMak I believe your recommendation will be incredibly helpful to others facing similar situations. That's why I decided to mark it as the Best Answer.
Thank you again for your willingness to help!
