01-22-2023 10:51
01-22-2023 10:51
How do I switch this off? I'm in the middle of a football game and want to check the time but it's running a stopwatch tracking my exercise automaticvally. I don't want this. It's then a pain to stop the exercise tracking in the middle of sport when I just want to see what time it is! So frustrating.
I've turned off (or tried to) automatically tracking but it won't go away!
help
01-23-2023 04:52
01-23-2023 04:52
Swipe right or left till you see the exercise/work out display, click on start training, click then on a training, scroll down and there you can find to turn the auto recognising exercise off (or on). Maybe you have to do this process with all the work outs, because I had to do it with mine, all individually.
01-23-2023 03:03
01-23-2023 03:03
Is this called the workout mode? Whatever it is, I want to switch it off.
01-23-2023 04:44
01-23-2023 04:44
@SMDprofile The Sense 2/Versa 4 have a new auto detection feature that is different from the SmartTrack feature. It's in three exercise shortcuts: Walk, Run, and Bike. I think this is what you are experiencing. As you discovered, it's on by default in each shortcut. Here's how to turn it off.
I also want to point out that you can see the current time when you are intentionally using any shortcut in the Exercise app. The middle screen has a number of real time stats. The current time is one of the middle stats that you see by tapping on the screen. The Sense 2/Versa 4 both let you customize the top, middle, and bottom stat. You can set the current time to be the top or bottom stat, if you want.
I hope this helps.
Laurie | Maryland
01-23-2023 04:52
01-23-2023 04:52
01-23-2023 05:38
01-23-2023 05:38
thanks both.
this should be a lot more intuitive.
