auto recognising exercise
ANSWERED
How do I switch this off? I'm in the middle of a football game and want to check the time but it's running a stopwatch tracking my exercise automaticvally. I don't want this. It's then a pain to stop the exercise tracking in the middle of sport when I just want to see what time it is! So frustrating.
I've turned off (or tried to) automatically tracking but it won't go away!
help
1 BEST ANSWER
Accepted Solutions
Swipe right or left till you see the exercise/work out display, click on start training, click then on a training, scroll down and there you can find to turn the auto recognising exercise off (or on). Maybe you have to do this process with all the work outs, because I had to do it with mine, all individually.
4 REPLIES 4
Is this called the workout mode? Whatever it is, I want to switch it off.
@SMDprofile   The Sense 2/Versa 4 have a new auto detection feature that is different from the SmartTrack feature.  It's in three exercise shortcuts: Walk, Run, and Bike.  I think this is what you are experiencing.  As you discovered, it's on by default in each shortcut.  Here's how to turn it off.
  • Open your Exercise app either by short pressing the button > Exercise -- or -- swipe to your Exercise tile on the screen and choose All
  • Select Run
  • Swipe up on the tiny "^" at the bottom of the screen to go to the settings for that shortcut
  • Swipe up to Walk detect and toggle it to Off
  • Repeat these steps in the Run and Bike shortcut
I also want to point out that you can see the current time when you are intentionally using any shortcut in the Exercise app.  The middle screen has a number of real time stats.  The current time is one of the middle stats that you see by tapping on the screen.  The Sense 2/Versa 4 both let you customize the top, middle, and bottom stat.  You can set the current time to be the top or bottom stat, if you want.
I hope this helps.
Laurie | Maryland
thanks both.
this should be a lot more intuitive.
