In Fitbit sense., the AOD clock face is moving left to right (like screensaver). While moving the clock looks distorted. This need to be fixed.
Also., this can be exposed as configurable setting for AOD., so that users who don't like clock face moving left to right can turn it off. if this option is already available, please share the steps to turn it off.
Hi @SunsetRunner - the reason for this AOD behaviour is to stop burn in, but it doesn't stop higher battery usage. A simple solution is to swipe the watch face down to get to Quick Settings and turn off all icons except Brightness [ which may or may not work]. That way you will see the watch display as soon as you raise your wrist, as it's quite sensitive it will be there and you can save battery.
