01-15-2021
09:45
07:58
WilsonFitbit
01-15-2021
09:45
07:58
WilsonFitbit
Would be a great asset to be able and answer texts received on the Sense by Alexa while you are on the go.
Best Answer@Rich_Laue is right. And if you are in the US and switch to Google Assistant on your Sense, you should be able not only to reply to the texts, but also to ask (voice) Google Asisstant to send a text.
Hello @Rawkit12 Welcome to the Community Forums! @Rich_Laue @Marrrmaduke Thanks for the input!
Currently, that option isn't available. But take into consideration that we're constantly striving to improve Fitbit products and services, and we very much appreciate all of the input we receive from our customers. So I suggest you to please give us your idea and suggestion through our Ideas board.
If you find that a similar suggestion has already been made by another member of the community, you can vote for their idea and add your comments.
On a side note, I invite you to visit the following link to get more information about how to use a voice assistant on your Fitbit watch.
How do I use a voice assistant on my Fitbit smartwatch?
See you around.
