03-13-2021
03:51
05:56
WilsonFitbit
03-13-2021
03:51
05:56
WilsonFitbit
Keep trying to access gems but just won’t work ?
06:01
06:33
03-13-2021
06:01
06:33
Hello @Ginger999, welcome to the community forums!
I'm sorry that the Agenda isn't working. Please check that the correct steps to set up the Agenda app are being followed:
Keep in mind that you must allow the Agenda app to access your calendar and run in the background. For more information about adjusting an app’s permissions, see: How do I install and manage apps on my Fitbit watch? If the Agenda app is correctly setup but your events don't appear, check the following settings:
You may also try to open the Fitbit App > tap on your profile picture and then on Sense. Go to Apps tile and scroll down do Agenda app. You should see the button "Uninstall". Tap it. Once the app gets uninstalled, reboot your phone and Sense by pressing and holding the button for 10 seconds until the screen goes black and logo reappears. Following the reboot, open the Fitbit app and install Agenda app again.
Hope this helps!
Best AnswerDo you see any error or messages of instruction when opening the agenda app, @Ginger999
Mine says to setup permissions.
In settings, all my calendars show, yet none have been accessed by Agenda App.
Today I turned all permissions off, and setup again. Finally the Agenda is working.
03-15-2021
09:25
06:33
03-15-2021
09:25
06:33
@Ginger999, thanks for your reply! @Rich_Laue, it's great to see you around and thanks for your input!
@Ginger999, I'm glad to know that the Agenda has started working!
Have a great day!
