04-02-2023
19:20
18:37
LizzyFitbit
04-02-2023
19:20
18:37
LizzyFitbit
Hello long time user here and if the developers could do anything about this I would be greatful, I literally don’t use the wallet or the weather, or voice assist on my sense it would be nice if like apps we installed willinngly we could uninstall those features so they wouldn’t be on our watches or the phone app!
Best Answer04-04-2023 11:58
04-04-2023 11:58
Hi @AndyCyclist - did you check the watch Settlings to see what you have assigned the button press?
04-03-2023 20:05
04-03-2023 20:05
Hi @ElizabethAnn85 - there are some things you can't remove but some have permissions in the Gallery tile than you can disable.
Is it a problem that they are there, if you don't use them, in the sense they are not doing anything unless you accidentally invoke them?
Best Answer04-04-2023 08:11
04-04-2023 08:11
I don't use Wallet, but half the time when I look at my watch to check the time, the screen is showing the "Set up Wallet" screen. Somehow I'm accidentally pressing the button. I'd like to at least disable, if not remove.
04-04-2023 11:58
04-06-2023 08:27
04-06-2023 08:27
Ooh, I didn't know about that. Thanks!
