11-08-2020
13:54
16:37
LizzyFitbit
11-08-2020
13:54
16:37
LizzyFitbit
Hello, I'm using my brand new Sense for about 2 weeks purchased via Amazon. Even on first setup I wasn't able to add any Wi-Fi network. Even adding it manually I wasn't able to connect. Updating the firmware through Bluetooth took really long and failed several times showing the big red "X". Every time I tried to search for Wi-Fi network through Fitbit app my Sense showed the WiFi logo without connection and restarted ultimately. Doing factory reset didn't helped.
Any solution?
11-13-2020 17:58 - edited 04-18-2023 12:22
Hi @misot79 , welcome to the Community Forums. @FloppyDrive and @Rich_Laue, thanks for your great help, you're awesome!
@misot79, thanks for your efforts while trying to get your Sense connected to your Wi-Fi, as well for attaching a picture of the error displayed. I understand how you're feeling about this situation and I'll give you a hand with this. Before anything else, please make sure of the following requirements:
Your have an open, WEP, WPA personal, and WPA2 personal Wi-Fi networks. Note that your watch cannot connect to 5GHz, 802.11ac, WPA enterprise, or public Wi-Fi networks that require logins, subscriptions, or profiles.
If those requirements are met, I'd recommend to try the following:
Let me know how everything goes.
Best Answer11-08-2020 16:00
11-08-2020 16:00
Have you restarted your wireless router recently? Have you looked at the logs on the router?
11-08-2020 20:39
11-08-2020 20:39
11-09-2020 00:08
11-09-2020 00:08
Are you saying the Fitbit app is unable to discover nearby WiFi ssid's? If your phone has WiFi enabled, then it would be an application permission issue on your phone.
11-09-2020 05:43
11-09-2020 05:43
Best Answer11-09-2020 10:10
11-09-2020 10:10
When setting up the WiFi, I find it is best to have the phone connected to the WiFi.
First question is your WiFi 2.5 compatible?
11-13-2020 11:25
11-13-2020 11:25
Unfortunately it looks like Fitbit software issue. I have tested it on 4 different routers and one is pure 2,4 GHz. But I wasn't able to find any networks in the Fitbit app. My Sense shows it searches, and it restarts several times. I should test it on different smartphone than Pixel 2. My overall impression about Sense is really poor. I'm thinking about returning the product and getting much cheaper Garmin Venue Sq.
11-13-2020 16:09
11-13-2020 16:09
Are you running Android 11?
Best Answer11-13-2020 17:58 - edited 04-18-2023 12:22
Best Answer11-15-2020 01:38
11-15-2020 01:38
I would like to thank you for detailed workaround for Sense WiFi connection problems. I did everything as you described. Removed Sense from Bluetooth devices list, cleared cache, force stop Fitbit app, rebooted the watch and even rebooted my Pixel 2 phone and repeated cleaning cache and force stopping the Fitbit app. I manually synced the watch in the app, did WiFi search and no network was found. I have several WiFi networks in range my phone can see them not the Fitbit app. I'm loosing my hope. As the device restarts repeatedly ie while doing WiFi connection attempts or while using Alexa assiastant. I think it may be faulty piece and thinking about replacement. I known that WiFi is used for firmware upgrades and music. But last time firmware upgrade through Bluetooth took really long time. Best regards Michal Šotola
11-16-2020 12:10
11-16-2020 12:10
Hi @misot79. It's good to see you around.
You're welcome and thanks for the time taken while trying those steps. I'm sorry that your Sense is still unable to find and connect to your WiFi network. This shouldn't be happening and because the troubleshooting tips didn't work, I've contacted our Support team so they can create a case and provide you with further assistance. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
See you around.
13:59
07:18
JuanJoFitbit
11-25-2020
13:59
07:18
JuanJoFitbit
I also have problems with connecting. The watch find the wifi, but even though I enter the correct password, it tells me wrong password 😞
As you can read above I also am unable to connect to wifi. The watch finds the wifi but refuses to accept the correct password, even if it is correct
Updates via bluetooth take extremely long time. The first installation took a night, now this first update seems to stop early on.
As you can read above I also am unable to connect to wifi. The watch finds the wifi but refuses to accept the correct password, even if it is correct.
Updates via bluetooth take extremely long time. The first installation took a night, now this first update seems to stop early on, and I have retried several times
Moderator edit: merged replies
12-20-2020 14:51
12-20-2020 14:51
On original Sense setup my wifi was not detected, went thru setup again - same thing. Being new I read the forum ALOT, found this - followed the instructions exactly -. This not only setup my home network wifi but IT ALSO CONNECTED MY SENSE CONTROLS!!!!!!
LizzyFitbit thank you, thank you and btw thank you again!
12-27-2020 13:57
12-27-2020 13:57
Also can’t connect to WiFi
01-28-2021 20:15
01-28-2021 20:15
Try changing the encryption method in the router from AES to TKIP. Worked for me.
Best Answer04-30-2021 19:06
04-30-2021 19:06
Isn't that less secure
I am getting the same error with wifi setup and nothing is working. 😞
04-30-2021 19:28
04-30-2021 19:28
Yes, it absolutely is. It's still the only way I was able to make it work. Everyday I own this thing I regret my choice more. 😕
06-08-2021 21:03
06-08-2021 21:03
Same problem. We even dumbed down a channel on our wifi. It looks to have connected but then when I try and change to a new face I get the "Oops, looks like there's no internet connection" message in the App. Our Wifi seems to think it's connected but I can't get anything to work. I'm very disappointed.
06-29-2021 11:03
06-29-2021 11:03
I have an iPhone XR. I've been using the Charge 4 for the last couple of years. Not very happy with it. I just got my Sense on 06/28/21 from eBay. On the initial setup, Sense would not connect to the wifi at my house. I didn't remember being told in the instructions to keep my Sense connected to the charging cable. Fortunately, Bluetooth handled the updates but it was slow. I have tried several times to connect. On several occasions, I would check the system info on my Sense and it would show the wifi connected. But if I backed up a screen and then went back into the system info the wifi would no longer be connected. I have also tried to connect at my office but the same problem. I have followed the steps you gave misot79. I reset my router and had the watch within 2 feet of the router. Same problem. It appears to connect but seconds later it is disconnected.
10-15-2021 20:41
10-15-2021 20:41
I had the Fitbit sense for about 2 weeks before having this problem. Fitbit finally decided that it was a faulty piece but then I had to wait over a month to get a new one and the new one is having the same problems. I will never own another Fitbit ever again.
