05-05-2021
09:06
17:40
LizzyFitbit
05-05-2021
09:06
17:40
LizzyFitbit
Hi Guys,
I'm an EMT and I can't use this watch without seconds on "Always On" display. Is this feature available?
Thanks!
Best Answer05-06-2021 04:01 - edited 04-07-2022 11:31
You can use a different clock face from the gallery that displays seconds, such as SimpleClockDuo, and set the default screen timeout to 60 seconds.
The problem with Always On is that it uses a lot of battery. The SimpleClockPro has an Always On mode which can be turned on and off from the front face as and when needed.
Best Answer04-07-2022 11:19
04-07-2022 11:19
looked for one, same reason
there is one called digichronooctagons
07-14-2022 15:06
07-14-2022 15:06
Thank you!!!
