07-13-2022 16:36
07-13-2022 16:36
I've been having issues with my Fitbit Sense over the past several days. I plug it in and the logo shows on the screen but it won't charge. I've tried 3 different charging cords, two different usb blocks and 2 different outlets. At times, I get a triangle with a thermostat showing but it's in my house at 72 degrees.
I've rebooted it several times by holding down the button for 10 - 12 seconds. I've also deleted the app from my phone and re-added it.
Before the "black screen" appeared, I was having problems with the sensors (measuring sleep, heart rate, etc)
I purchased my fitbit sense in September of 2022
Am I SOL?
07-13-2022 18:24
07-13-2022 18:24
Same happened to mine on Sunday. Same story. Ive only had it since June so im pretty frustrated. Support has NOT been helpful so far. Hopefully someone has answers??
07-13-2022 18:48
07-13-2022 18:48
@LMig65 @kelsherrera87 , A warm welcome to the Community ! Thank you for your messages and feedback.
@kelsherrera87 , As you already are in contact with Support, let them know if the steps provided did not help. So that they can continue checking your case.
@LMig65 , If you haven't done so, please give a look at this: Why isn't my Fitbit device's battery charging?
See you around.
07-13-2022 20:54
07-13-2022 20:54
Same issue, went through the why isn't my fitbit charging, new cord, new usb ports, new wall plug cleaned, etc. Any other suggestions?
07-14-2022 04:45
07-14-2022 04:45
@JuanFitbit I did take a look at Why isn't my Fitbit devices battery charging and listed all the things I've already done in my original outreach. Reaching out to Fitbit was my last effort.
07-14-2022 16:38
07-14-2022 16:38
I purchased by fitbit sense in September 2020
07-14-2022 18:08
07-14-2022 18:08
@Liltrix @LMig65 , Thank you for your replies and confirmations.
In that case, you should give our team a call or chat with them.
They'll be more than glad to take over your cases.
Here you'll find our contact info.
See you around
