11-02-2021
06:37
14:01
LizzyFitbit
11-02-2021
06:37
14:01
LizzyFitbit
It seems few apps that users can find useful in Versa 3 / Sense's app gallery. Is there any app on your watch that you would recommend to other users?
11-02-2021
09:20
06:02
11-02-2021
09:20
06:02
HI, SimpleTimer has many more options than the Timer app, such as the button does stop/start, remember last countdown, Repeat, Auto start, optional Display always on, etc..
Ability to switch to Alarms if more appropriate.
21:57
06:02
11-02-2021
21:57
06:02
Try also SimpleCheckUp which shows on your watch when it last synced, if it can connect to the phone, details about the watch and time zone it is on, abity to find phone. Saves using phone to check syncing and connecting information.
22:45
06:03
11-04-2021
22:45
06:03
Hi @deiG - this is a good question as there are only a few good apps.
When SimpleTimer is used as an addon app to the SimpleClockPro clock face, double tap on Seconds anytime to see Timer view.
Double tap on the Timer counter to switch to the clock face view again.
The clock face Seconds show blue if a stopwatch, or green if a timer, is currently running.
22:39
06:02
11-06-2021
22:39
06:02
If you have two Versa, or later, watches, by using the SimpleCheckUp App you can immediately check on the watch when the second watch last synced, so you don't have to keep logging out of one account and logging into the other to check when it was last synced.
This means the second watch can go for at least a week or more, depending on usage, without having to switch accounts.
This is especially useful if the primary watch is a Sense or Versa 3, because at each login you have to tediously complete the Voice Assistant setup and go through accepting the Stress Management score agreement process every time.
