09-28-2020 05:56
09-28-2020 05:56
I am trying to add my Bluetooth devices and it won't find my airpods for some reason. Anyone have this problem? Know of a fix?
Best Answer09-28-2020 07:44
04-16-2021 16:19
04-16-2021 16:19
Hi I’m having this same problem. How did u get it to work?
Best Answer04-16-2021 18:40
04-16-2021 18:40
You need to put the Air pods into pairing mode.
Make sure that Bluetooth is on. Put both AirPods in the charging case and open the lid. Press and hold the setup button on the back of the case until the status light flashes white. Select your AirPods in the Devices list, then click Connect.
