04-09-2023 06:35
04-09-2023 06:35
G'Day,
I discovered a post from 2020 that explained why my Sense couldn't connect to my 5G Wi-Fi for setup but did not want to disconnect all my connected devices to change it to 2.4G so I used Bluetooth instead.
The app showed that it was happily setting up my device via Bluetooth, even though my device was only 57% charged.
Then the app stopped working because it said my device had low battery.
Thinking I hadn't connected the charger correctly (or forgot to turn it on) I checked the device and it assured me it was 93% charged.
Refer to my other post about setup issues that are 6 years old to understand what I think of this product.
Garry
Best Answer04-09-2023 07:00 - edited 04-09-2023 07:01
No issues here that you are experiencing
Best Answer04-10-2023 01:40
04-10-2023 01:40
G'Day Clove6060,
This was the initial setup and I restarted the setup and it eventually went through OK.
I just don't like it when a device tells me something that is untrue, like today when I apparently rode a bike outdoors (twice) even though I never went outside the front gate.
Thank you
Garry
