So, I updated my Fitbit Sense last night. My watch is maybe almost 2 weeks old. I powdered it off last night with a battery charge of 98%. When I powered it back on this morning (without any additional charging) my battery said it was at 87%. Why is my Fitbit Sense losing battery while it is completely powered down?
06:55
05:47
08-03-2021
06:55
05:47
Welcome back to the Community forums, @Carnella.
Thank you for the information provided regarding the inconvenience that you've been experiencing with your Fitbit Sense.
Let me know if you're also having this problem when the watch is not turned off. Just in case that this is related to the battery, please follow the steps provided in this article, as this has been useful to other users experiencing something similar.
In addition to the steps mentioned earlier, make sure that you've also completed the restart procedure described here.
Hope this helps, I'll be around.
So far, I haven't noticed the battery to drain drastically when it the watch is not turned off. The battery drains about 10% a day while it is powered on. I'll keep an eye out for if the battery drains when I randomly tend to power my watch off. How often should the Sense be powered off?
Best AnswerRight!! I thought that it was very strange for my brand new watch to drain while powdered off, especially after I just the did the recommended update for the watch and charging it.
What is the average daily draining amount for the battery?
A sense has a built in SpO2 tracker which if you use the watch lightly should enable it to last 4 days on a charge. If used more extensively it could be less. See here for more thorough explanations.
@Carnella Thank you for your reply.
If you continue to experience the same inconvenience with the battery draining too fast when the watch is turned off, I do recommend that you get in touch with the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I'll be around if you have further questions.
Thank you! I haven't powered my Sense off again yet, but if I do continue to see the battery drain while powdered off I'll contact customer support.
