Hi there. I have my sense Fitbit which seems to quickly be depleting it's battery life. Even tho it says 6+ days. It has never lasted me that long but it should. Why is this not lasting as long.. all I do is put it on my wrist and use it. Is there any way I can get this fixed...
I've done everything?!!!?
Best AnswerHello @Rideordie13, This issue is mostly related to the clockface your using as some of them can quickly drain out your battery. All the clockfaces that I use usually give me about 5-6 days. I have made some of my clockfaces (both paid and free), that don't inhale your battery. If those clockfaces don't help then it could be the device itself. Contact Fitbit support here.
Weather Face (best battery life) [PAID]
Clean Stats [FREE]
Other clockfaces
If this answer works please mark this post as a Best Answer. ~ K.K Designs
Best AnswerHi, @Rideordie13, welcome, it depends on what you are doing with your "Sense". The latest function "Snore report" involves having the microphone on all night with the inevitable drain on the battery. If you use the "Sense" GPS this too will impact the battery reserve. FYG I use my "Sense" to track a 90 minute swim each day and about 60 minutes GPS tracked walk plus normal activities, resulting in a 25% drain. This is without the "Snore Report". You do not say how long your "Sense" does last. You may find this article of interest Can I extend my Fitbit device's battery life?
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
