When I first purchased my fit bit the battery lasted just over a week before needed charging now I'm charging every 2-3 days nothing has changed no new apps etc of anything I'm on holiday from work and not using it as much
Best AnswerVery unhappy with this now 😞 I get this would happen over time but not in this short of time only had it just over a year it won't last a day soon the way it's going. Actually I charged it the other day was about 1 hour after taking off charge and it had used over 10% of the battery.
Best AnswerDo either of you have the snoring function turned on where it listens for snoring at night? I had it on initially at it would discharge 25-30% at night.
Seems many are having buggy experiences with it recently.
Readiness report uses a lot of battery as well.
Turn that off
Here is a link to review the various issues with battery life, for locating the cause of the problem which could be as a result of an update.
How to resolve the Major issues causing short battery life.
