08-10-2022 20:08
08-10-2022 20:08
Sense battery is draining within 48 hours
Best Answer08-10-2022 22:01
08-10-2022 22:01
https://myhelp.fitbit.com/s/support?language=en_US
Best Answer08-11-2022 04:04
08-11-2022 04:04
Same here. If you're using the features you bought it for, that's probably the best you're going to get.
Best Answer08-11-2022 04:18
08-11-2022 04:18
Did you do the update? Formaly it appaered too after an update for the Ionic. A lot of **ahem** afterwards
Best Answer08-11-2022 04:33
08-11-2022 04:33
I've been getting ~48 hrs battery life since purchasing my sense, I'm using all the 'premium' features. I did update yesterday so I don't have enough enough time to say what the impact is on battery life....
