08-06-2022 19:32
08-06-2022 19:32
I can’t get the weather to work. It
Keeps showing that I need to update it I’ve updated about 20 times and it still doesn’t work. I’ve therefore added weather bug so at least I can see the weather. Is anyone else having trouble?
Best Answer08-06-2022 20:02
08-06-2022 20:02
Hi @Kristimj7 - have you tried checking the weather permissions and removing cities, in the weather app in the Gallery tile in the Fitbit App and then syncing and swiping your watch face up?
Best Answer08-06-2022 20:17
08-06-2022 20:17
Yes I’ve checked the permissions everything is on it I can’t even add any cities because I can’t get the Weather app to work. It just keeps saying update so I run it but it never updates and when I go on my watch and click on TheWeather it just says I need go to the app and set it up. Which I’ve tried a bunch of times. I restarted my phone too.
Best Answer08-06-2022 21:06 - edited 08-06-2022 21:07
@Kristimj7 - in the Fitbit App, click profile photo, device photo, Gallery tile, scroll down to the weather app, click on it and there you have permissions and settings to set it up.
Best Answer08-07-2022 05:39
08-07-2022 05:39
Yup did that. All permissions are on.
06:43
06:20
08-07-2022
06:43
06:20
@Kristimj7- did you know you can chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
Best Answer08-07-2022 07:59
08-07-2022 07:59
Thanks I’ll do that
Best Answer08-10-2022 04:25
08-10-2022 04:25
There was an update and everything works now!
08-10-2022 16:00
08-10-2022 16:00
The problem with mine is it constantly stays on Celsius and won't change to Farenheit even with me having it set on Farenheit in the settings.
Best Answer08-10-2022 19:08
08-10-2022 19:08
I can’t get my watch to show Fahrenheit. It’s showing weather in Celsius.
Best Answer08-10-2022 19:09
08-10-2022 19:09
That's the same problem for me. Won't change to Fahrenheit even though it is set properly in settings.
Help!
Best Answer08-10-2022 20:16
08-10-2022 20:16
Hi @Hofstadbl , @lthompson893 , @nelsonsmoke20 - did you follow this link How to change Temperature - for Weather, Centigrade - Fahrenheit, Sense
Best Answer08-11-2022 06:21
08-11-2022 06:21
08-11-2022 06:31
08-11-2022 06:31
